 Hello
Not sure if this works but I give it a try.
I am working as IT support at a firm with 150 people. and every second Friday we meet up in the HQ and someone is joining us on skype. so 1 boss asked me if we could have a camera with wide angle that could go from the Computer and behind us. so the cabel should be 10-15m. is this even possible? a web camera that could record to skype that have an 10-15m long cable.
https://linustechtips.com/topic/829512-web-camera-for-group-meetings/
If one isn't that long from factory, you could extend manually with other cables etc...
Current Build:
CPU: AMD Ryzen 5 2600 // Mobo: Ryzen AM4 B350 GAMING PLUS ATX // RAM: 16GB Corsair Vengeance LPX DDR4 3000MHz // GPU: Gigabyte AMD Radeon RX 580 Gaming 8GB // SSD: Kingston A400 120GB // HDD: 3 x WD Blue 1TB // PSUCorsair 650M // Case: Corsair 450D // Monitor: LG Ultrawide 29" IPS
Plex Server:
CPU: AMD FX 8350 Black Edition // Mobo: Gigabyte - GA-78LMT-USB3 R2 Micro ATX // RAM: 16GB Corsair Vengeance DDR3 1600 MHz // GPU: GeForce GTX 670 // HDD: Seagate BarraCuda 2TB // PSU: Kolink Core Series 500W 80 Plus Certified // Case: AVP Viper Mini Tower
Other:
PS4 Pro // PS3 // Nintendo Switch (Pokemon edition) // Nintendo 3DS // Xbox 360 // iPhone 8 Plus // Macbook Retina 2013
32 minutes ago, `WHooami said:
 Hello
You could use a dslr with a wide angle lense, and then have that go through a pcie capture card, Then use it as a video device, this will then let you use a 10-15m HDMI cable
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
i dont think they are in need of a so expensive solution, any decent webcam can be used when you use an usb extender i think. The usb extension is like 15$ for 15m
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
As long as it’s powered. USB webcams don’t usually like to go through extensions.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Solution might be 15m extension usb cable at which end you would have a self powered usb hub.
EDIT: after a few google searches this is a great answer i found:
I have used a 5 meter usb extension cable + the 1 meter camera cable for a security camera in another room that was no problem but it looks like that is the safe limit.
The 2.0 specification limits the length of a cable between USB 2.0 devices (Full Speed or Hi-Speed) to 5 meters (or about 16 feet and 5 inches). In other words, you cannot just connect a bunch of extension cables together (like taking a 6 foot cord and extending it with 4 other 6 foot extension cords) and run them 30 feet to another room. However, you can connect a 6 foot cable with a 10 foot extension cable for a total of 16 feet, which is below the maximum cable length for USB 2.0.
How to break the USB length limitations: With the USB specs limiting the length of cables, is there a way to extend those limits? Yes! However, in order to go beyond these cable length limits (or recommended lengths) you need to use self-powered USB hubs or active (repeater) cables; both of which have their own limits as well. Other options such as USB over Ethernet or building your own USB bridge can extend the USB range further.
Maximum length of USB active (repeater) cable: This number depends if you are using a regular cable with an active cable or not. If you are not using a regular cable, then the maximum active cable length for USB 2.0 is 30 meters (98 feet and 5 inches) and the maximum recommended length for USB 3.0/3.1 is 18 meters (about 59 feet). If you are using a regular cable (max length of 5 meters for 2.0 and max length of 3 meters for 3.0/3.1) with an active cable, then the maximum length for USB 2.0 is 25 meters (about 82 feet) and the maximum recommended length for USB 3.0/3.1 is 15 meters (about 49 feet).
 Is there any way to go beyond the limit of active cables or hubs? There are other ways you can extend a USB signal beyond the 30 meter limit. You can use USB over Ethernet to achieve distances up to 100 meters (about 328 feet). Additionally, you can build your own USB bridge to transmit data over different communication channels such as wireless methods.
