So I have been a console peasant for a long time and I finally decide to make the evolutionary jump to PC, but I am a full noob with the idea of building a pc so I did the logical think to do seek a pre built, I saw one on ebay but I don't know if it is good or bad or a scam, is a full PC with keyboard a mouse and even a monitor, here are the specs, give me any advise or opinion you have
Marke: ASUS SI Possessor type: AMD FX
Manufacture number: 20140008 GPU: Radeon R5 230 1GB
Screen size: 54,6 cm Processor speed: 4,0 GHz
Guaranty: 3 years Ram : 8GB
Form factor: Tower Operative system: Windows 10
Hard Drive: HDD (Hard Disk Drive) Operative system version: Professional
HDD-Hard drive capacity: 1TB Manufacture country: Germany
link:http://www.ebay.com/itm/GAMER-PC-KOMPLETT-mit-MONITOR-AMD-FX4300-FULL-HD-TFT-8GB-1TB-WINDOWS10-Pro-/272104010220?hash=item3f5aa9b1ec:g:l7wAAOSwutpZlTqa
https://linustechtips.com/topic/829392-advise-for-a-pc/
really bad computer, honestly buying an old dell with a 2000 series cpu and buying a gtx 1050 TI would suit your purposes much better
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/829392-advise-for-a-pc/#findComment-10377974
I'll tell you what every else is going to tell you; just build it yourself.
Advantages of a custom build:
Chose your own parts
Far cheaper
Far more reliable (don't come with shitty powersupplies and garbage cooling)
Better upgrade options (prebuilds usually come with a crappy motherboard and tiny powersupply)
In some cases, longer warranty (eg corsair PSU's are atleast 5 year warranty whereas some prebuilds only offer a year warranty)
Far more cost efficient
Advantages of a prebuilt:
You don't have to build it
honestly, it's nicknamed adult lego for a reason. Ofcourse you won't know how to build a pc, and you never will until you try it. The parts go in set places and nowhere else, it's hard to screw it up.
edit: that pc is trash and you could build a far better one for $100 less
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/829392-advise-for-a-pc/#findComment-10377988
Give me a budget and I'll spec you out a PC\
do not buy that computer. ever.
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/829392-advise-for-a-pc/#findComment-10378000
@Armakar +1 , Honestly it doesnt take a genius, i learned it by straight out buying some parts that people said were good and fallowing mobo manual directions, watch like a few videos about building pcs and you will be at least 10 times more experienced than i was with my first build
https://linustechtips.com/topic/829392-advise-for-a-pc/#findComment-10378002
as stated above, it isn't hard to build a computer, i watched a few short videos while in the process of buying parts, when it came to building it, it was fine, the hardest thing or things would probably be cable management or the CPU cooler depending on what you get
https://linustechtips.com/topic/829392-advise-for-a-pc/#findComment-10378057
