Just cause 3 has weird ghosting issue
fastcar123
When I play the game and I have anything moving on screen it creates this very odd effect.
The best way I can describe it is like multiple copies of the same image displayed over the moving object.
So for example, if I am in a car driving around I will see a small trail or that same car following me.
This may not sound like a big deal but the more movement on screen the worse it gets. So cutscenes are so hard to watch because of this issue.
All I really know about it is that turning v sync on helps helps tremendously, as the game is unplayable without it.
For a long time I though it was my monitor, but since it's the only game with that issue I'm not thinking it's a hardware issue.
Is there something I can do to reduce or eliminate it?
can you maybe post a screenshot so we can see what you mean?
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
