pc spec
SABERTOOTH x79
I7
16gb of vengeance ram
2 gtx 980 in sli
cx750m corsair psu
I was use the PC and it just turn off, no blue screen. Now it wont boot. when i try to turn it on the led on the one fan turn on then back off and I don't get a beep code. I have tried clear CMOS and a new psu. I don't know where to go from here any help would be appreciated.
https://linustechtips.com/topic/828561-need-help-pc-wont-boot/
8 minutes ago, patfatnot said:
pc spec
SABERTOOTH x79
I7
2 gtx 980 in sli
cx750m corsair psu
First thing I would try is take off the RAM, reseat it,
Try one stick at a time also.
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
https://linustechtips.com/topic/828561-need-help-pc-wont-boot/#findComment-10369173
