Hey guys! This is going to be the start of the planning and execution of a wall-mounted PC build.
The truth be told is that I'm not the most experienced when it come's down to DIY, so this will either end up beautiful (with the trusty assistance of you able individuals); or absolutely terrible.
Whilst my PC knowledge is okay, I'm absolutely terrible when it comes to building anything. :$
To begin with, what would you say was crucial for a wall-mounted PC build? Maybe some of you have built one previously and can impart some tips to assist me as I progress?
29/08/2017: Currently compiling my part's list which are due to be ordered via next-day delivery at the weekend.
Thank you in advance!
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.”
― Charles Bukowski
Desktop | Intel Core i5 - 7600k | ASUS Strix B250F | MSI GeForce GTX 1080Ti x Gaming 11G | 256GB Samsung Evo | x2 WD Blue 1TB | Corsair Vengeance LPX (2x8GB)
Mini Desktop | Mac Mini | Core i7 2.3GHz | 8GB RAM | 1TB HDD x2
Laptop | MacBook Pro 13in w/Touch bar (2016) | Intel Core i7 | 8GB LPDDR3 | 1TB SSD
Laptop | Lenovo Thinkpad Edge | Intel Core i5 | 16GB DDR3 | 256GB SSD
Peripherals | Razer Chroma Orbweaver | Magic Mouse 2 | Corsair K70 RGB | Logitech G402 | Blue Snowball | Logitech G922 | Logitech Artemis Spectrum G933
Galaxy Tab S2 - used as a media streamer, more often abused by my 1 year old son.
https://linustechtips.com/topic/828515-wall-mounted-pc-build/
Great tip - get that airflow in there, little heat and quiet af is also beautiful
subscribe to pewdiepie
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10368658
Little heat, quiet af and great airflow - noted! xD
― Charles Bukowski
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10368681
what is your plan for this wallmounted build? are you going to keep it on air or are you going to watercool, and if so, what is the layout you're planning?
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10368734
I was thinking about integrating water-cooling, but this is an area that I haven't stepped into in the past. I'll probably just stick with a water-cooled CPU block but I guess issues may arise with creating a custom mount to attach the radiator to. I would love to integrate a custom water-cooling system, but I don't want to run before I can walk. Do you have any suggestions?
12 hours ago, Merp83 said:
Curiosity - how much ya spending? and what specs do you have planned?
I'm looking to go above and beyond my current spec. I'm still debating whether to have an AMD build as my current PC is Intel.
If it was AMD, I would follow this build but may swap out the RX 480 for a 1080.
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  (£407.94 @ Aria PC)
CPU Cooler: Deepcool - Maelstrom 120K 61.9 CFM Liquid CPU Cooler  (£39.99 @ Ebuyer)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  (£109.89 @ BT Shop)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  (£148.80 @ Alza)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (£86.97 @ Amazon UK)
Storage: Seagate - FireCuda 2TB 3.5" 7200RPM Hybrid Internal Hard Drive  (£84.84 @ Aria PC)
Video Card: Asus - Radeon RX 480 8GB ROG STRIX Video Card
Power Supply: Corsair - RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£84.20 @ Amazon UK)
Total: £962.63
Generated by PCPartPicker 2017-08-30 10:21 BST+0100
Where as if it was Intel, I would swap the Ryzen 7 for an  i7 - 7700k and use the same motherboard but the Intel socket variant - I would probably explore buying the Intel chip set second-hand also!
Edited by HunterScott
Specify purchasing route of Intel i7 7700k.
― Charles Bukowski
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370605
Total: £962.63
Where as if it was Intel, I would swap the Ryzen 7 for an  i7 - 7700k and use the same motherboard but the Intel socket variant!
well if you want to go low profile and your budget allows it you could ask parvum for a flat res. just check them out they are awesome
also dont just screw it all to a wooden board and mount it get creative
oh and maybe try 3d modelling it if you can to get an idea of what itll look like
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370610
I'll definitely take a look at Parvum - thank you for the referral. I've been exploring various 3D printing options, and with the huge reduction in price for consumer models and their increased practicability, I may buy one to use in conjunction with this build and others in the future.
― Charles Bukowski
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370614
sounds cool just make sure to use print material thats sturdy and can take a bit of heat - just in case
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370617
Do you have any suggestions for consumer level 3D printers within the £300 mark?
― Charles Bukowski
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370634
well it depends on what you are comfortable with. me personally i would get the anet A8 from china for 150ish bucks or so.
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370641
Something user-friendly and easy to get the hang of really. I'll have a look at the A8 - thank you once again!
― Charles Bukowski
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370661
idk about all that but i heared it has good accuracy and quality for its price but there is still some assembly and tinkering required i think
https://linustechtips.com/topic/828515-wall-mounted-pc-build/#findComment-10370890
