Fan Layout Recommendations?
Solved by LogicalDrm,
I'd say just put it rear exhaust. 2 front intake and that as exhaust will be enough.
Side question: Why is GPU at bottom PCIe slot? It won't gain anything from there and might even run bit hotter since there isn't direct airflow towards it.
1 hour ago, themctipers said:Rad on top. Slightly better because hot air goes up.
Intake from the front is alright too.
Irrelevant inside PC case.
