On 29/08/2017 at 0:28 AM, dreamlight said:
Is there a way to change quick settings drop down menu color without root?
If using a most recent android version changing the theme or creating your own cab change either the look or colour of the pull down menu
------(]CATASTROPHIC FAILURE[)------
https://linustechtips.com/topic/828140-quick-settings-question/#findComment-10375561
