Minecraft 1.7.2 LAN doesn't work.
Hi guys!
I want to play in a LAN world with a friend of mine (He's here so where on the same network) but when one of us enables LAN the world doesn't show up in the multiplayer menu.
I have enables uPnP on my router and when i check Minecraft port forwards though uPnP. I also turned Firewall of on both computers but still doesn't work?
Help please?
Thanks
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/82798-minecraft-172-lan-doesnt-work/
I'm using 1.7.2 LAN with no issues.  It is pretty straight forward and vanilla setup...
Some computers are on OS X and others on WIN7 with no special firewall exceptions specific to minecraft on any of the machines (OS firewalls are turned on).  ie, we didn't touch or change firewall settings to get it to work.
We didn't need to touch any settings on our router.  ie. No port forwarding on the router for minecraft ports.  upnp is disabled on the router.
try disabling upnp
Also check that your antivirus doesn't have it's own firewall or filter that may be blocking the port/connections.
