First time Pc building
Go to solution Solved by seon123,
GTX 1080, G3 instead of G2, 250GB SSD, Ryzen 1600.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.43 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.99 @ SuperBiiz)
Storage: Toshiba - 3TB 3.5" 7200RPM Internal Hard Drive  ($77.34 @ OutletPC)
Video Card: Asus - GeForce GTX 1080 8GB TURBO Video Card  ($514.98 @ Newegg)
Case: NZXT - S340 Elite (White) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($70.98 @ Newegg)
Total: $1237.68
Generated by PCPartPicker 2017-08-28 10:35 EDT-0400
DON'T GET A 7600K! Get a Ryzen 5 1600 with a B350 board, it's much better!
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10362971
Total: $1237.68
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363013
Total: $1237.68
is it still easy to upgrade in the future even tho i got a bit of a low end motherboard.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363022
3 minutes ago, Maxan98 said:
Colexd Why?  what more do i earn from having a ryzen 1600 with a new motherboard
1st of all it has 6 cores and 12 threads versus 4 cores 4 threads. It will be better in almsot everything especially in the next years where devs start optimizing games to take advantage of more cores. Secondly, the platform is dead and you have to switch to a new motherboard if you want to upgrade in the future.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363031
It has 4 RAM slots, an M.2 slot, 6 SATA ports, and a VRM which should cope with Ryzen 7. And the socket is going to be supported until 2020, which is quite a bit a longer than Z270, which is done in october. Much more sensible if you're going to upgrade, compared to the 7600K.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363045
that was pretty solid build from @seon123 .I noticed you tried to maintain aesthetics too..if you can raise a little bit budget you can swap the board to asus b350f strix & IMO then you are perfect for 2/3 years than your previous build :D
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363058
get os from reddit for $20-30.
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($59.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.38 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB D5X Video Card  ($514.98 @ Newegg)
Case: Deepcool - DUKASE WHV2 ATX Mid Tower Case  ($49.99 @ SuperBiiz)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($42.98 @ Newegg)
Wireless Network Adapter: Gigabyte - GC-WB867D-I REV 4.2 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $1163.70
Generated by PCPartPicker 2017-08-28 10:52 EDT-0400
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363078
Total: $1237.68
no OS or wireless adaptor and over budget.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363085
As many have said, the 1600 is a good choice - but be prepared to lose a couple of frames in single-threaded games.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363123
Forgot about the wireless adapter, and standard Windows from Kinguin or Reddit. Tried to keep the same case as OP, and missed the TXM for $40.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363126
1 hour ago, Maxan98 said:
Im trying to find parts to build my first gaming PC. I look to play with 1 monitor and my budget is around 1200 dollars. This is the parts i think would be good. PS: not going to play fps
https://pcpartpicker.com/list/9yJyM8
What monitor are you going to be using ?
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363244
23 minutes ago, Maxan98 said:
1920 1080
I would swap out the i5 in your initial build for a Ryzen R5 1600 and B350 board such as the Asus B350-F Strix.
A Seagate Barracuda (Green label) is also cheaper than the WD Black.
The Corsair TXM 550W is also cheaper if you are going to use rebates. Works out around $50 or so.
I would also look at adding an SSD if you don't already have one. Something like an SK Hynix SL308 250GB.
The GTX 1060 will do ok for 1080p. You definitely don't need anything higher than a GTX 1070.
Oh and up the Reds! :D
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363335
what if i would like to get an screen with 1440p.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363384
A GTX 1070 can handle 1440p. I guess it depends on the monitor you have in mind whether it would be worth going with a 1080/1080 ti etc, although that would increase your budget quite a bit.
https://linustechtips.com/topic/827928-first-time-pc-building/#findComment-10363419
