Linus Tech Low End Build
Solved by Swedish Sam,
Thanks for all the help, this is my updated list, any thoughts on the cases/psu
CPU: AMD A8-5600K 3.6GHZ X ($112 AUD @ Umart AU) or AMD FX-6300 3.5GHz 6-Core Processor ($135 AUD @ Umart AU)
Motherboard: ASRock FM2A55M-DGS R2 ($62 AUD @ Umart AU) or ASRock 980DE3 ( $82 AUD) Not sure if first one will work with the 2nd cpu ^^
Memory: G Skill 8G(2x4G) DDR3 1333MHZ ($94 AUD @ Umart AU) - this has been pretty much decided
Storage: Western Digital Blue 1TB SATA3 HDD 7200 RPM ($65 AUD @ Umart AU) - this has been pretty much decide
Video Card: Sapphire ATI HD 7770 ($118 AUD @ Umart AU)
Case: CoolerMaster Centurion 5RC-502SKRL II Silver Case 500W PSU ($96 AUD @ Umart AU) or CoolerMaster NSE-300-KKN2 Black USB3.0 NO PSU ($49 AUD @ Umart AU)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified ATX Power Supply ($81.50 AUD @ Umart AU) or INCLUSIVE in case
