it's not so much the class but the deck type you build with it. each class has a tendency for some of those because of strong or essential cards to the deck.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10353929
Just now, Daniel Z. said:
k thnx, im using warlock rn
warlock with base cards tends to go Zoo. which means lots of small dudes to flood the board right from the start trying to pile up the damage before enemy can get big clearing cards or blocks.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10354059
k its lv 4 rn
yeah no worries. and i don't know if you bought packs with money or not. so this might not apply to you. because even though basic decks still work the new stuff is more mature and much stronger because of the available variety
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10354067
no i havent spent money
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10354069
Some classes prefer fast play style more. That's only difference. Rest is about what kind of deck you choose. I'd recommend making account to Heartpwn site snd using their Innkeeper tool to see if you can make some cheap (in dust) but effective decks. Or just check listings for ideas.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10354694
k, I have a pretty decent lv8 warlock deck rn
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10355201
Lvl 8 doesn't really mean that much. It only tells that you have 52 free cards to get. I don't quite understand why Blizzard even has levels. Other than giving rewards for going one up. Ranked ladder is one to test if something is good of not.
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10355386
k i wll
https://linustechtips.com/topic/827057-hearthstone-help/#findComment-10355390
