I have a gtx 1050 been using it more than 2 weeks now, runs perfect. but just this day it just glitches out of no where, can run some games but glitches,crashing or black screen just out of no where and some games cant even run. I didnt do anything particular so I am really confused on how Am i going to fix this pls help. :((
https://linustechtips.com/topic/826980-help/
Have you tried reinstalling drivers? Made sure power connectors are properly plugged in?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/826980-help/#findComment-10353059
Yep. Reinstalled drivers ,checked the cables, restarted the pc still not yet fixed.  even the steam notification when friends go online just blank no txt at all. tried to benchmark Shadow of mordor and got glitches all over my screen. maybe I should return and probably get a replacement if I didnt get any solutions
https://linustechtips.com/topic/826980-help/#findComment-10353081
Try using a DDU when uninstalling and reinstalling your graphics drivers. You can grab an install from http://www.guru3d.com/files-get/display-driver-uninstaller-download,19.html.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/826980-help/#findComment-10353093
I recently had the same problem. thought it was the drivers too....... but I had a case fan in front that died not bringing in crucial air flow and the card was getting hot. Maybe check air flow, maybe try repositioning fans, maybe maybe adjust fan speed on card. Maybe pop side off case for a while.
maybe the new graphics card is hotter than old and maybe there's not enough air blowing down onto the cpu area?
maybe it is the drivers and I have yet to reproduce the effect. When it happened I was on 4k vs my usual 1920x1200......... which could be heat making the card work harder or still be software???? ( this was nvidia card too )
https://linustechtips.com/topic/826980-help/#findComment-10353103
