I'm looking for an Matx cube case since I like the look of them and the Corsair Air 240 is out of the question since it will not fit my graphics card and I don't want to spend more than $150 cad if possible
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/826739-matx-cube-case/
I have the diypc cuboid. It's kinda cheaper but it's a cube. It works
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350210
I really can't see why the 770 Twin Frozr wouldn't fit in the Air 240.
The data on Corsair's site seems off to me
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350213
No the width of the card is too wide it will bend the side panel windows
I should it nice to build in?
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350219
https://pcpartpicker.com/b/7m3Ff7?comment_sort=newest
Uses a 770 Twin Frozr in an Air 240
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350222
It doesn't have the best cable management, but it fit a hyper 212 evo, looks fine for a triple fan video card, and comes with two fans. It's fine to me.
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350225
Ok and it looks to fit properly
Currently I have an M9A for my CPU and it's cooling it pretty well
https://linustechtips.com/topic/826739-matx-cube-case/#findComment-10350266
