360mm radiator thoughts
Go to solution Solved by Leonard,
7 hours ago, Mr Mindstorms said:
So I've decided to upgrade my cooling to a Thermaltake Water 3.0 Riing RGB 360, (currently I have the maelstrom 120k aio liquid cooler). But my problem is with my case... Currently I own the Thermaltake view 27 and the only place to mount it is on the front, after reading some forums I found it may not be the best idea to mount it there as I'll draw hot air into the case. So what is everyone's thoughts on this? I've got an i5 7600k with a gigabyte gtx 1070 in standard configuration (facing down).
Thanks in advance
-Mr Mindstorms
Firstly, when you are copy and pasting text just right click the place you plan to paste it and select paste as plain text to avoid formatting. Night viewers see your text as black.
Secondly, the front radiator will PUSH hot air into the case after pulling cool air from outside, this is true but you can also use a high static pressure fan as just normal exhaust case fan in the back to help you defeat this issue. Now you might be able to mount the radiator outside if you are really worried about the heat but just mounting the radiator to the back via the one fan mount and the fans to the radiator then taking off the PCI- e brackets and sliding the block in and if it has enough free tube mount it to the MOBO.
Thanks in advance
-Mr Mindstorms
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/
Not much you can do with a 360 rad in that case. You're trading GPU temps for CPU temps.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344422
4 minutes ago, Mr Mindstorms said:
Roughly what temps are we talking here for the GPU though (let's just assume cpu is on 100%).
1. Quote me if you are replying to me. You're lucky I saw your reply.
2. No clue, and there's no real way to know without knowing exact overclocks/configs of everything and actually trying it.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344443
Also, what are your goals/reasons for getting a 360 rad?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344447
I've overclocked the 7600k to 4.8 ghz, so at the moment I'm sitting at about 40-45C idle and about 70-75C when playing games. So although I don't necessarily NEED the 360, it would help. Also RGB...
(Also Australia is going into summer soon and room temps are gonna get really hot)
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344473
Ah, kabylake. If you seriously want to push that overclock, you're going to need to delid. What is your GPU sitting at during use?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344484
Can't quite remember at the moment. Will check when I get home from school. But I believe I'm sitting at around 60-65 when in use and about 45 at idle. Again, these change drastically in the summer.
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10344513
Thanks in advance
-Mr Mindstorms
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/826232-360mm-radiator-thoughts/#findComment-10345339
