I'm looking to add an extarnal gpu to my hp probook 440. I'm planning to use this https://goo.gl/xUyXfZ to connect my gtx 1060. I'm having a slight issue though. I want a small preferably external psu that will work. My gtx 1060 only needs a 6pin power cable and any help or feedback would be nice! Thanks
https://linustechtips.com/topic/826085-looking-for-small-powersupply/
1 minute ago, Dylan2123 said:
Doesn't matter for now just looking for some options
CX450M
Whisper M 450
SeaSonic G 350
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
2 minutes ago, Dylan2123 said:
those are some big ones but thanks
I can't think of really small ones :/
Full Specs
Helios EVO (Main):
Delta - Laptop
Yes, but they are also rather good ones.
The smaller you go, the more sacrifices you have to take. I myself don't trust those open Frame or Pico PSU further than I can throw them. Even Small Form Factor units should be avoided if possible because the ATX units are way better than those.
And a decent +12V only PSU with some decent wattage is way more expansive than those mentioned above are...
So it's best to live with the size and not worry about other stuff...
"Hell is full of good meanings, but Heaven is full of good works"
There are SOME SFX units just as good as ATX units though...
such as the Corsair SF.
Full Specs
Helios EVO (Main):
Delta - Laptop
