Can you split a PWM signal without needing to boost it?
By
Metalshark
in Cooling
in Cooling
Solved by deadaccount69,
You are correct in assuming it's simply a control signal. The first 2 pins are power, the third is a tachometer(it pulses every time it makes one rotation) and the 4th is a control signal for a little transistor across the motor power. You should be able to simply splice it with no problems.
Featured Topics
Rbakker02 ·
Posted in General Discussion0 -
BaidDSB ·
Posted in General Discussion2 -
Mistr J ·
Posted in Troubleshooting3 -
1
4
2
coolbean28 ·
Posted in Graphics Cards8 -
awsomename999 ·
Posted in Troubleshooting4 -
RoyTheGeek ·
Posted in Phones and Tablets2
