Odd power supply mod
I have a project plan to put 3 xbox systems into one case. What i need is to figure out is how to connect the proprietary power connectors into the xbox by rewiring them to fit a different connector on a ATX power supply. Suggestions? If anyone has graphs or models of what does what on the Xbox power supplies do it would be great if you posted them. (Original Xbox, Xbox 360 Slim, Xbox One)
https://linustechtips.com/topic/825798-odd-power-supply-mod/
this sounds very odd but strangely awesome
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
https://linustechtips.com/topic/825798-odd-power-supply-mod/#findComment-10339645
1 minute ago, NovaMan01 said:
Very. Help?
I have no clue how to do it. never modded prebuilt things, only modded other stuff. ie non circuitry.
https://linustechtips.com/topic/825798-odd-power-supply-mod/#findComment-10339656
2 hours ago, Himommies said:
Well how bug is it.if it big enough you can just but evreything in and rewire it all.
or you can build your own and stack them vertically
Tru but im trying to avoud it. Im gonna end up just rewiring some stuff and shoving in a ATX PSU
https://linustechtips.com/topic/825798-odd-power-supply-mod/#findComment-10340077
this page has a pinout of the 360's connector: http://thevariableconstant.blogspot.de/2012/12/xbox-360-power-supply-hack.html
Please don't blow yourself up, 3 360's will use a lot of power.
I talk in brackets (a bit like this (sometimes multilayered) (I know it's hard to read but I sort of think like this(maybe it has something to do with being a programmer)))
https://linustechtips.com/topic/825798-odd-power-supply-mod/#findComment-10341204
