Custom unconventional build planning
I have a plan to put a original Xbox, a Xbox 360 Slim, and an Xbox One all in one case that is custom made. Before i begin designing the case, i need the dimensions of the motherboards and parts. Anyone know where i could find these measurements or 3D models of them so i can model in a program?
https://linustechtips.com/topic/825314-custom-unconventional-build-planning/
56 minutes ago, jcw150 said:
Sorry I can't help you but I would like to ask a few questions.
Why? (not in a rude way, it's a cool project)
What's your PSU plan?
How big do you expect it to be?
Thanks
Why: i got bored one day and was like "hey why not"
I plan to put the rear I/O on the back of the case, so i will just use whatever power brick came with the xbox. Im a little concerned about the original Xbox PSU though; its sketchy as hell
Probably ATX relatively
ATX motherboards and PSUs have standard dimensions. So do most PCIe cards (at least height and thickness); unless we're talking something silly like ARES II and the like.
Coolers usually ony have a height stated, check with manufacturer.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
10 hours ago, NewAndy said:
I can't help you with anything, but I wishyou good luck and hope you'll post a build log because this is kinda cool... or probably hot, considering you're using old Xboxes as your case...
The plan is to discard the old cases and custom design a case to put them all into
