You can't change fan settings on some motherboard, and your bios is not windows 8 it is the manufacturer of your motherboard bios.
What you can do to change the speed of your fans is to get a fan adapter from 12v to 7v or 5v
http://ncix.com/products/?sku=62205&vpn=BFA-MSC-M33F7VKK-RP&manufacture=BitFenix
http://ncix.com/products/?sku=62206&vpn=BFA-MSC-M33F5VKK-RP&manufacture=BitFenix
Or to get a fan controller to plug multiple fans into.
http://ncix.com/products/?sku=63082&vpn=ACC-NT-SEN-MESH&manufacture=NZXT
Or to the ghetto Linus way!
https://linustechtips.com/topic/8252-speed-fan-help/#findComment-93992
+1
https://linustechtips.com/topic/8252-speed-fan-help/#findComment-93995
-1, Check all your options before spending money, your fans might not undervolt well
AAAAAAAAAGGGGGGGHHHHH!!!!
https://linustechtips.com/topic/8252-speed-fan-help/#findComment-94207
