Wall Mounted PC Help
55 minutes ago, Ruffleduffle said:luke once made a wall mounted pc buy just bolting the components to a painted pice of mdf
Yeah I did that as well as the Thermaltake and Liam Li Wall mounted PC cases are Stupid Expensive.
At OP. Go grab a $2 case thats all busted up long as its not bent or warped, Dents are fine. Drill out the pop rivets and that gives you a way to mount the Motherboard and GPU's way easier.
buy a MDF board and make the two onto one and than just go from there.
You don't even really need the Motherboard tray and can get some great resutls with a PCIe extender cable and flat mounting the GPU.
Get Google Sketckup and play around in there. you can download models of all PC parts and try your hand at moving things around.
*Edit
here is my build log for one that I played around with, Was super cheap and unfortunately just ran out of time with me moving countries
