So, I'm looking for a power supply for my WHS 2011. Current specs are as listed:
(Dell Enterprise Grade Workstation)
Intel Pentium D @ 3.6Ghz
1TB WD Caviar Green
120GB Sandisk Extreme SSD
Dell 300-350 Watt PSU
What I plan on doing is doing my own server build this summer. Here are my ideas for that so far: (Subject to change)
Fractal Design Define R4 (It's going to be very visible) :p
Intel Core i5 3570?
Some Sort of Mid-Range Motherboard
LSI MegaRaid 9260-4i
4 to 6 WD Red 3TB Drives
And for the power supply.......
What PSU would you recommend getting that would work for the build I am planning? (Don't say Corsair AX 1200i)
I need to get it fairly quickly before I kick my server out of a window. The loud squeaking noise makes me suicidal (not really, but kinda) Seriously though, it's coil whine with BAD Turrets.
So, what PSU would you recommend? My preferred brand is Corsair, but any reliable brand works for me. Keep in mind that this does not have to be server grade, just reliable and quiet.
Addressing the fact that I have a Dell motherboard, yes it does use a standard ATX PSU, so any standard power supply works.
Thanks in advance,
AndrewReaganM
CPU: Intel Core i7 3770K  CPU Cooler: Corsair H100 (2x SP120 Quiet Edition)  Motherboard: ASUS Sabertooth Z77  RAM: Corsair Vengeance 8GB 1866MHz  PSU: Corsair AX850  GPU: EVGA GTX 670 FTW 2GB  SSD: Samsung 850 Evo 500GB
https://linustechtips.com/topic/8242-home-server-power-supply/
First of all, as far as your server specs, you're not going to be able to run those 6 WD reds off of that lsi raid card. It only has one sff-8087 connector, which equates to only 4 drives, not 6. To run more than 4 drives off of it you need a sas port expander such as this:http://www.newegg.com/Product/Product.aspx?Item=N82E16816117207&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Controllers+%2f+RAID+Cards-_-N82E16816117207&gclid=CM71uOLSnrYCFQjhQgodiicAMw
For a server like that you're only going to need a 400-500W unit. Unfortunately corsair doesn't have a high end unit in that wattage range, only stuff like the CX series, which is fine if you want to go corsair, but the CX units (if I remember correctly) are OEM'd by Channel Well, which makes good stuff but not the greatest. I would go with a seasonic unit. For a server you'll probably want the efficiency and it sounds like noise really bothers you so you might want to go with one of their fanless platinum units. They're definitely pricey, but they're rock solid.
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
https://linustechtips.com/topic/8242-home-server-power-supply/#findComment-92769
I realize the card won't support 6 drives, hence I put the "4 to 6" next to the drives... :p I really don't want to spend too much on a PSU, so I will probably just go for a mid-range Seasonic, or something.
Thanks,
AndrewReaganM
https://linustechtips.com/topic/8242-home-server-power-supply/#findComment-93002
