Hello, I'm kind of new to pfSense and need help with setup. I have an intel core i5 3470 and 8gb of ram on a Biostar h61 mobo. For my NIC I am using an intel PRO/1000 Ptquadport. When I do the setup for pfsense everything is fine until I am to setup the WAN and LAN ports, pfsense only recognizes em0(the WAN) and nothing else. I only have my modem hooked up to the NIC via ethernet cable, how do I setup so I also have LAN. Any help is appreciated.
https://linustechtips.com/topic/823955-pfsense-help/
10 hours ago, Riceis5life said:
Just tried both, still no luck
Did you connect both WAN and LAN during the installation? Did you configure them both?
https://linustechtips.com/topic/823955-pfsense-help/#findComment-10321918
1 hour ago, Riceis5life said:
I connected my modem to my NIC, but non of the interfaces show up, just the one on the motherboard
1000 PT has built in driver support, have you checked the Status > Interfaces tab to see if they are present?
Please quote or tag me if you need a reply
https://linustechtips.com/topic/823955-pfsense-help/#findComment-10322608
2 hours ago, Riceis5life said:
Is that in the web GUI, I don't have access to that
Yes,
If you don't have access to the other quad port NICs do the following;
Set the following IP on your WAN interface;
IP - 192.168.0.1
Subnet - /24 (255.255.255.0)
Gateway - None
Then within the Console, goto Command Line and type - pfctl -d
This will disable the firewall completely (until you make an ammendment)
Then plug your laptop/desktop to the WAN port, assign yourself the following IP information;
IP 192.168.0.2
Subnet - 255.255.255.0
GateWay - 192.168.0.1
DNS - 192.168.0.1
Then goto;
https://192.168.0.1 in your web browser on the laptop/desktop.  This will give you access to the WebGUI within pfSense, here you can see if the interfaces exist or not.
https://linustechtips.com/topic/823955-pfsense-help/#findComment-10323135
1 minute ago, Riceis5life said:
nothing else other than the wan is there
Nothing present in available network ports at the bottom?  If not the card is clearly not being detected, I use a PT1000 in another machine, is the PT a PCI-Express card?
I would also check your BIOS to make sure the PCI-Express slot the card is using is active.
https://linustechtips.com/topic/823955-pfsense-help/#findComment-10324785
