So i have this problem that i am not sure about.
CPU: Ryzen  5 1600
GPU: GTX 1060 6gb
MOBO: MSI b350 pro gaming
HDD: 3000gb baracuda
PSU: Corsair rmx 550w 80+ gold
RAM: DDR4 2x4gb 3200mhz
And 3 case fans.
My question is will this 550w 80+ gold puwer supply from corsair run just fine without a problem?
Because i was just playing dying light and suddenly my screen went black and the fans stopped turning only the motherboard lights were popping up. When i removed the GPU it worked perfectly fine.
https://linustechtips.com/topic/823335-pc-problem-help-please/
CPU: Ryzen  5 1600
GPU: GTX 1060 6gb
And 3 case fans.
You should be fine in theory, so I have no idea why that isn't enough power unless that Ryzen CPU + 1060 + HDD combo is a problem.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/823335-pc-problem-help-please/#findComment-10313886
The PSu should be enough.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/823335-pc-problem-help-please/#findComment-10313890
The thing is i build this pc couple days ago. I was just playing a game and then it suddenly went off. Only the mobo lights were on. So i looked it up and pulled the gpu out and then it worked fine. But whenever i try to play a game it feels like the psu is not enough or something to handel my rig. :(
https://linustechtips.com/topic/823335-pc-problem-help-please/#findComment-10313913
and its not the ram i checked i switched it from places
https://linustechtips.com/topic/823335-pc-problem-help-please/#findComment-10313917
Do you have a way to measure power consumption under load with the GPU and without the GPU?
https://linustechtips.com/topic/823335-pc-problem-help-please/#findComment-10313926
