So recently I've upgraded my system to ryzen and thus began running some firestrikes to get a solid score. After the first test I noticed my graphics score had severely decreased compared to when I was running an 8320. Most of the scores I've others have got with this gpu are around the 13000-14000 range while mine only scores 9200. The temps are below 60 so it shouldn't be thermal throttling either. One thing which is abnormal is the gpu load during firestrike. Any help would be much appreciated. If more information is needed just ask and I'll provide it.
Current system
Ryzen 1700
ASUS 1060 Strix oc
X370-PRO
16 G of corsair vengeance DDR4 3200MHz(Currently running at 2133 if I recall correctly)
700w bronze psu.
https://linustechtips.com/topic/822857-problem-regarding-asus-1060-strix/
6 minutes ago, BaronCrux said:
Won't boot at any higher speeds.
you tried 2933MHz? My C16 Vengence 3200MHz RAM would only go that far, and I did see an improvement in CB15 scores when the RAM is fast.
manual timings.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
9 minutes ago, BaronCrux said:
brb I'll try it now.
As expected it doesn't work. From what I hear higher memory speeds aren't working for most people with ryzen. Anyways I'm not sure how it would even help my gpu not performing as it should.
