Sennheiser G4ME ZERO surround sound adapter?
1 minute ago, JerrBear said:I'm not familiar with audio, but I found this here: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/68176-asus-rampage-v-extreme-x99-motherboard-review-15.html
I have the Asus Rampage V Extreme X99. I see it's onboard sound is listed as "very good", but I don't know what to compare it to/interpret that.
One thing to clarify: So that adapter doesn't somehow give the headset high-quality surround sound? My HyperX Cloud 2 has some button on the adapter for 7.1 virtual surround. Is that a part of the GAME ZEROs?
the virtual surround is a software based solution, so that adapter isnt going to do shit for that, its basically just an amp. it might help to aid the quality of the audio by increasing max volume, but thats basically it.
i dont know about that boards audio personally(and im not an audio guru so those numbers mean very little to me honestly) but the best thing to do is, plug the headphones in and listen to your music and games. if it sounds good, then great! if its muffled or sounds like ass, you might consider getting a dac/amp which will help a LOT more than whatever that adapter can do.
