Hello, My name is Kristian, I'm from Latvia and currently have a pc mainly to play Rust or Path of Exile. I've come across a weird issue recently where while playing path of exile, my game simply crashes on itself, and I doubt it because of my systems specs (Will list below). And a few minutes before writing this post, my computer froze completely, for the 2nd time, but this time my headset was spewing sound repeats as if 1 note was played really quickly on repeat, and also changing the pitch, till shortly ~10 seconds later, it stopped and the red light on the pc stopped blinking. I'm assuming my hard drive is starting to fail, but I'm not sure so I'm asking here for help.
(Images) Display 1 is 1360x768 (32bit) (60Hz) [Both are LG, but display 2 is a TV with HDMI, Display 1 is a monitor but VGA, cause my GPU doesn't have 2 HDMI, only VGA, DVI, HDMI.)
https://linustechtips.com/topic/822666-malfunctioning-hard-drive/
6 minutes ago, NextGenFirex said:
snip
Try run a HDD test utility, there is one WD's website. Not sure about seagate.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
try opening taskmanager then right click on game exe
is there an option callad virtualize?
or set cpu affinity to 2 cores max(game engine crash on multithread data)
3 minutes ago, NextGenFirex said:
About a year. bought it pre-built from a company in my country. Would have listed the specs for it here, but they updated their gear and that list is now gone.
Well make a backup for your pc on a flash drive just in case it fails and run a test on it or it could be the games problem do you see this problem repeatedly on other applications?
also does the hard drive make funny sounds?
That one?
Yes, only in Path of Exile it crashes, most of the time suddenly. And while having the game open for now, i hear no unfamiliar sounds.
I have the results from the diagnostics test, and it's a PASS, so I guess it's a problem with something internally?
1 hour ago, NextGenFirex said:
snip
Try resinstall your audio and graphics drivers. They have caused issues for me in the past.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
4 hours ago, NextGenFirex said:
That one?
i dont remember it saying UAC but if this does what i think then it shouldnt hurt to have enabled
i think most effective will be set affinity(max 4 cores)
do you have 1 or 2 hdd drives???
this not fast drive for write but decent on read as you can use dvdrw drive and disc but set disc to be an open/not finalized burn session
now windows will write and read the dvdrw as if it were a hdd drive
this makes for a good temporary files drive or if fast write speeds a nice pagefile drive
