Help! The SATA ports running off my chipset's storage controller don't work
2 hours ago, NumLock21 said:
So bios shows device plugged into intel sata port? This verifies, the  controller is working.
Yeah, however clearly not working properly.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
Connect your new SSD into the Intel SATA port and reinstall the OS. Have you done that yet. If not, then do it.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
I tried. The Windows Install Media gives me an error saying "Windows cannot be installed on this drive". Don't remember exact wording of the rest but it talked about how my motherboard may not support booting from this drive, and that I should check to make sure the controller is enabled.
During Windows setup, can it see your SSD? If yes, then try it on SATA port 0. With some boards, Windows setup tends to be picky. Now if your SSD was some how formatted as GPT, you'll need to boot the windows setup as UEFI.
AMD ThreadRipper 2!
I can see the SSD in setup just like I can in BIOS. I tried it in all 6 Intel ports including 0 and got the same error message. It actually was formatted as GPT, but I converted it to MBR and still had this other problem.
You will need to remove the entire partition of your SSD. To do that, boot with your OS setup and go to command prompt. Then do a diskpart, select your SSD drive, and type clean. Make sure you don't wipe out your windows usb boot drive or any other drives that's attached to it.
When complete restart system and run setup again.
AMD ThreadRipper 2!
That's what I did. I cleaned and then converted to MBR. I've already got Windows installed on the SSD, just with it running through one of the ASMedia ports.
Can you repeat what you did, and this time with the Intel SATA port?
AMD ThreadRipper 2!
When I do, I get the other error telling me that something's up with the controller and Windows can't be installed on the drive.
Okay then, it's a possibility that your Intel SATA ports are faulty, but it's not 100% confirmed because I've seen the same error you have on different systems and none of them are the SATA port themselves. There are PCIe to SATA adapter cards, to add some extra SATA ports for your computer.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=pcie+to+sata+controller+card&rh=i%3Aaps%2Ck%3Apcie+to+sata+controller+card
AMD ThreadRipper 2!
Okay then, it's a possibility that your Intel SATA ports are faulty, but it's not 100% confirmed because I've seen the same error you have on different systems and none of them is the SATA port themselves. There are PCIe to SATA adapter cards, to add some extra SATA ports for your computer.
Yeah, I'll probably just pick one of those cards for cheap and be done with it.
