I'm looking to upgrade my pc in the next few days as my motherboard has stopped working.
My budget is $1000 AUD for the upgrade but I would like to save money if possible.
My goal is too run Overwatch with 250+ fps on all low settings whilst streaming too twitch using obs. (I dont really mind what quality the stream is as long as its watchable)
I would like to over clock (I have never over clocked before)
The parts that im keeping are:
  • EVGA GeForce GTX 970 4GB ACX 2.0
  • NZXT S340
  • Corsair CX 600W 80+ Bronze
  • And my two monitors (1 is 60hz, 1 is 144hz)
My planned parts for the upgrade are:
  • AMD - Ryzen 7 1700
  • ASRock X370 Taichi ATX AM4
  • Corsair  Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Also if there is anything that would help to improve ping that would also help. (I am using Ethernet ATM)
Any tips to improve this would be greatly appreciated.
Cheers Harry
https://linustechtips.com/topic/822204-ryzen-upgrade-help/
According to http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1070-vs-Nvidia-GTX-970/3609vs2577 you would gain 30 fps @ 1080 high settings in overwatch for 122 fps over 93 fps. No specs for low settings are given though :/ . You could ebay the 970 for the crypto miners, I just looked on ebay https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR12.TRC2.A0.H0.Xgtx+970.TRS0&_nkw=gtx+970&_sacat=0 and it looks like the card it going for about 200 dollars which would offset the cost of the 1070.
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302295
1. Your current PSU sucks. Corsair (Actually, the OEM that produced this model for Corsair) cheaped out the parts inside so they degrade faster than a PSU should. If you have used it for more than 3 years then replace it so it doesn't have a chance to fry the PC.
2. What's your current CPU and why are you upgrading?
3. X370 board is unnecessary unless you need SLI support or like the looks so much. Otherwise, get the cheaper B350 ones
Desktop benching:
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302328
Im upgrading because i want too stream and my i54690 cant
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302377
My budget is only $1000 AUD so even if i could sell my graphics card for $300 i would still be around 300$ off, which i money i dont have, I also need this by the end of the week, as my current motherboard has stopped working and i need an upgrade.
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302385
Dont x370 boards have better VRMs, better DDR4 support, better LAN, and audio.
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302408
Yes, but B350 ones already have appropriate amount of VRMs.
B350 and X370 all support 3200MHz DDR4 at most.
LAN speed is the same
You will need a very good audio system and ears to hear the difference. Not like those on X370 can replace professional sound cards anyway.
Desktop benching:
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302440
ok cool
https://linustechtips.com/topic/822204-ryzen-upgrade-help/#findComment-10302456
