i want to generate a image from video using C#. dont know how to get this done,so i checked online and found this code below but im having trouble understanding it.if anyone could explain what it does in a simple way as im not very good in programming it would be very helpful.thanks
public static Bitmap GetThumbnail(string video, string thumbnail)
    var cmd = "ffmpeg  -itsoffset -1  -i " + '"' + video + '"' + " -vcodec mjpeg -vframes 1 -an -f rawvideo -s 320x240 " + '"' + thumbnail + '"';
    var startInfo = new ProcessStartInfo
        WindowStyle = ProcessWindowStyle.Hidden,
        FileName = "cmd.exe",
        Arguments = "/C " + cmd
    var process = new Process
        StartInfo = startInfo
    process.Start();
    process.WaitForExit(5000);
    return LoadImage(thumbnail);
static Bitmap LoadImage(string path)
    var ms = new MemoryStream(File.ReadAllBytes(path));
    return (Bitmap)Image.FromStream(ms);
source: https://stackoverflow.com/questions/15702031/get-thumbnail-image-of-video-file-in-c-sharp
https://linustechtips.com/topic/821691-need-help-understanding-this-c-code/
Basically, the code is running FFmpeg from the command line using the Process class.
Here is some documentation to explain the Process classes in more detail
FFmpeg is generating an image from the specified video (ie: the video parameter) and saving it to the specified location (ie: the thumbnail parameter) which you can then load into your application (ie: the code in the LoadImage method).
