Hello, I've got my hands on a modular PSU called; Huntkey x7 900w but when it was too late I realized it had no cable for the CPU, does anyone know how I could get one of these cables or I could use any cable?
This has been very troubling for me and I appreciate any help!
Also there is some pictures attached if it helps at all.
-Thanks, Simon
https://linustechtips.com/topic/821544-psu-modular-lost-cables/
-Thanks, Simon
Welcome to the Forums!
Your most likely going to need to contact the manufacture, but in all honesty I've never heard of this brand so I wouldn't fully trust it's reliability as a PSU.
https://linustechtips.com/topic/821544-psu-modular-lost-cables/#findComment-10294993
Where did you buy the PSU from and are the cables in the box?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/821544-psu-modular-lost-cables/#findComment-10295029
Just now, Slyzx said:
Yeah its kinda of an ancient psu and I didn't do my research before buying it, hopefully I wont need to fork out more money for the cable or a whole new psu :/
Return it if there is no cables and the icons below the text can be helpful for quoting so people know when they were talked to
https://linustechtips.com/topic/821544-psu-modular-lost-cables/#findComment-10295032
Bought it cash in hand and stupidly I didn't check the cables that came with it, my bad on my end. It only came with a SDD/SATA cable and the 4 PCIe cables.
Contact the guy and say you didnt include everything
https://linustechtips.com/topic/821544-psu-modular-lost-cables/#findComment-10295047
Yeah, im trying to do it but I think he did a fast one and I'm trying to make the best from worse. The PSU does work as the fan spins and stuff.
Thats ok but you would need to have the rest of the cables to test it fully
https://linustechtips.com/topic/821544-psu-modular-lost-cables/#findComment-10295065
