Im currently planning out my first ever budget custom pc build. It'll mainly be used for programming, video editing and some light gaming; rocket league, minecraft and paladins at most.
I've chosen to go with a mini-itx form factor, so that way in case I ever need to bring it somewhere I can do so without having to bring a big beast.
If you dont mind, could you please go over my list and tell me about anything that you think would be helpful for me to know.
List: https://www.amazon.com/gp/registry/wishlist/3EA9V3DM8L5F1/ref=cm_wl_huc_title
Thanks.
($600 budget)
https://linustechtips.com/topic/821463-first-pc-build-build-compatibility-check/
Firstoff, I'd recommend using PC partpicker. it's much better at finding better deals, and it's easier to make a build with it.
second, I think you're putting too much CPU, and not enough GPU.
in your place, I'd go for something like a 1050Ti at least. even a R3 1200 OC'ed to 3.9Ghz, and a GTX 1060/RX 580 would be way better.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
GUYS
massive issue - motherboard is micro ATX but the case is ITX!
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
1 minute ago, Shiv78 said:
GUYS
Nice catch.
@KamdenBolhuis, this is why you should use PC partpicker. it catches these issues.
Laptop:
I made a new list.
It's slightly over budget, and the CPU is a bit weaker than I'd like, but GTX 1060 + R3 1200 (OC'ed to 3.9) is a way better combo than R5 1600 + GTX 1050, or even R5 1400 + GTX 1050 Ti
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($108.99 @ SuperBiiz)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($68.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Best Buy)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($269.89 @ OutletPC)
Case: DIYPC - MA01-G MicroATX Mini Tower Case  ($21.98 @ Newegg)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($39.99 @ SuperBiiz)
Total: $609.82
Generated by PCPartPicker 2017-08-13 14:07 EDT-0400
Laptop:
SSD keeps it nice and fast, with a pretty powerful GPu and similar case.
ITX is expensive on Ryzen so mATX instead. Cheaper case and HDD would get you to a RX580 4GB or GTX 1060 6GB.
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2400 Memory  ($62.99 @ Newegg)
Storage: SanDisk - Ultra II 240GB 2.5" Solid State Drive  ($84.95 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($209.68 @ OutletPC)
Case: Thermaltake - Core V21 MicroATX Mini Tower Case  ($59.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $626.58
Generated by PCPartPicker 2017-08-13 14:08 EDT-0400
HOLA NIGHT THEMERS
OTHER TECH I OWN:
2 minutes ago, KamdenBolhuis said:
What I've changed:
Changed the proccessor to a Ryzen 5 1400.
GPU switched to gtx 1050ti 4gb
Much better.
GTX 1060 + R3 1200 might still be better, but that's up for debate.
make sure you either get fast RAM, or OC the RAM you get. fast RAM can give up to 20% performance improvements on Ryzen.
Laptop:
Total: $626.58
Cringe at 3GB version of 1060.
seriously, that card is almost as good as a 1050Ti
Laptop:
fast 8GB DIMMs are rare/expensive so OC it is
HOLA NIGHT THEMERS
OTHER TECH I OWN:
What
Much better.
What ram would you suggest?
Just now, KamdenBolhuis said:
What
like @Shiv78 said, it's really hard to find fast 8GB memory, so just OC some normal 2133 or 2400 memory.
you can follow the memory OC guide in my sig. (credit to magetank)
Laptop:
Thanks! I'll take a look.
It's really not.
HOLA NIGHT THEMERS
OTHER TECH I OWN:
remove hdd if you have an old one lying around or you think 250gb is enough for os+everything
Total: $672.57
Generated by PCPartPicker 2017-08-13 14:20 EDT-0400
1 minute ago, seon123 said:
You currently have a Ryzen CPU with an LGA1151 motherboard. Change the motherboard to one with the B350 chipset
lolwut he changed it
All AM4 miniITX boards are $110+
HOLA NIGHT THEMERS
OTHER TECH I OWN:
That's an AM4 board
Laptop:
1 minute ago, RadiatingLight said:
That's an AM4 board
yep, he changed it.
get an mATX case. Ryzen ITX is bad, and more expensive.
Laptop:
