Help, Modflex sleeving size
Go to solution Solved by W-L,
6 hours ago, Groundedbeef said:
Is there anyone here that knows the diameter of cablemod - C-Series ? Its Modflex sleeving
I am looking for cable combs either 3 or 4mm ones,
On the Cablemod homepage i can get combs that fit but they do not sell 14 slot witch is the ones that i need. Also they are alot cheaper at E22
They're approx 3mm or 1/8":
https://linustechtips.com/topic/821356-help-modflex-sleeving-size/
@Groundedbeef ModFlex is 2.8mm and ModMesh is 3.1mm
Ahh a rep, aweseome.
Are you making 14 slot combs or are you planning to do so? a closer look and your combs looks better, i like the round edges.
Also is there a way to purchase them seperately?
@Groundedbeef can you please email this to Support@CableMod.com - can check on that there for you. :)
