Hi I would like some advise on the new pc parts I would be planning on buying. I would need some help to see if the parts I would be getting would be the best parts for my money
1. Budget & Location
 i would like to stay under $800 and I live in the US
2. Aim
  a lot of gaming  and some video editing
3. Monitors
 2 acer 1080p 75 hz monitors and planning to stay that way
4. Peripherals
 I have everything I need including a geforce gtx 780 graphics card everything else needs upgrading except hard drives, ssd, power supply.
5. Why are you upgrading?
bc my pc can't perform as good as i would like it to and be as silent as i would like it.
the only reason i'm not upgrading my graphics card rn is bc I don't feel like it is very necessary at the moment but will be a upgrade in the future.
the pc parts i have chosen are on a theme of a white and black build.
https://pcpartpicker.com/list/Mcz7LD
please give me your feedback and changes that would help me a lot for saving money.
this is my first post so please if I forgot anything tell me.
and idk if that fan controler will even work can anyone suggest a better one.
https://linustechtips.com/topic/821249-pc-upgrade-help/
you could get something along the lines of a ryzen 1600 and have better CPU multithreading for video editing, while retaining most of your FPS in gaming
if you really are settled for intel, wait for a bit for coffee lake, it will probably have 6 core mainstream SKUs and the new CPUs won't be compatible with any existing 100 or 200 series motherboards.
edit: https://pcpartpicker.com/list/kvHzD8, did use the cheapest B350 motherboard as I don't know what you're looking for in a motherboard, B350 and X370 can overclock any ryzen chip. B350 can't SLI or CrossFire though, while X370 can.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10292098
2. Aim
3. Monitors
4. Peripherals
night theme friendly ^
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10292116
3 minutes ago, crankshaft10 said:
yea i like intel thanks tho for the info about coffee lake cpus.
consider ryzen though
ryzen 1600 crushes i5 7600K and is cheaper
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10292117
Just now, crankshaft10 said:
 I would but does it crush the i7 7700k?
not in gaming, yes in EVERYTHING else
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10292134
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($32.49 @ Newegg Marketplace)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($131.49 @ Newegg)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($152.99 @ Newegg)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($99.98 @ Newegg)
Total: $614.83
R5 1600 is definitely the better choice and more than adequate for 1080p 75Hz. A GPU upgrade would help more for gaming. You can get this cooler instead if you want;
https://pcpartpicker.com/product/mjdqqs/phanteks-cpu-cooler-phtc12dx
but you'd need to contact Phanteks and ask for an AM4 mounting bracket. You can also get this cooler in black with white fans for $10 less.
It would be useful if we knew the rest of the specs though so we know what you're holding on to, and what might be worth keeping as a CPU upgrade might not be wise or necessary. For a GPU upgrade, I'd probably aim to get RX Vega 56 or GTX 1070, or if you go with the CPU upgrade for now and wait a while, maybe GTX xx60 or GTX xx70 Volta.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10292574
yea i saw that air cooler but needed the am4 bracket and all of have rn i have a i5 4460 cpu, asus b85m-g motherboard, 8gb drr3 ram, gtx 780, 1 tb hard drive, 120gb crucial ssd, corsair 600 watt psu.
and planning to keep the hard drive, ssd, psu, and gpu.
not sure but might need to upgrade my psu it does have a 8 pin motherboard connection not sure.
https://linustechtips.com/topic/821249-pc-upgrade-help/#findComment-10293887
