I have bought a cooler master Hyper TX3 EVO and blue screen appeared : ***STOP: 0x00000124 (0x0000000000000000, 0xFFFFFA8006B57028, 0x00000000BE000000, 0x0000000000800400)
My pc spec is:
Core i3 2120
4gb Elixir 1333mhz
ASRock B75m r2.0 (BIOS is up to date which is version 1.20)
500gb WD Caviar Blue 7200rpm
Sapphire HD6570 2gb DDR3
Standard My 10's mid tower case
450watt PSU (standard psu)
Standard Samsung DVD-RW combo
https://linustechtips.com/topic/8210-i-need-help/
Check you didn't knock or pull out any other wires like sata cables or power leads. Also make sure the cpu fan power header is connected to the cpu fan power pins. Make sure that the new cooler is located correctly and fully pressed down on the cpu (not loose). Also make sure that ram is seated correctly as it quite easily to not a ram dimm/stick out of place slightly.
MB: Gigabyte Auros Gaming 7 Z370 Cpu: Intel i7 8700K @ 4.8ghz Gpu: Gigabyte GeForce GTX 1080 G1 Gaming OC 8GB Ram: Corsair Vengeance LPX 64GB DDR4 DRAM 2400MHz  Psu: Corsair RM1000i
Ssd's: WD Green nvme m.2 512gb (boot), 480gb (Steam), 480gb (Uplay) and 480gb (Origin)  Cooling: Corsair Hydro Series H115i 280mm
 Case: Corsair Obsidian Series 900D Monitors 1: Asus pb287q @ 75hz
https://linustechtips.com/topic/8210-i-need-help/#findComment-92536
Check that all your connections are inserted properly. If that doesn't work, try just using 1 stick of ram to boot if you have 2 or more sticks.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/8210-i-need-help/#findComment-92600
Your stick of RAM on one of them is dead I received a kit of 3 and one of the RAM sticks did not work looked at the code and saw the same error except on a different pin. One of your pins on you RAM is scratched or not working. I would recommend to rule out and test which stick is causing that error. I fixed in a metter of 1 hour but my computer beeps when I have a RAM problem so it was easier to diagnose.
The Asian is Everywhere
https://linustechtips.com/topic/8210-i-need-help/#findComment-93054
This is quoted from a mod on the microsoft forums
This issue occurs because resource rebalancing is triggered after you hot plug a PCI (Peripheral Component Interconnect) device. During the rebalancing process, the system does not configure the Max Payload Size value correctly on the root port of the PCI Express bus. The incorrect value causes a mismatch between the root port of the PCI Express bus and the device on the PCI Express bus. Therefore, the operating system triggers a Machine Check Architecture (MCA) exception, and the operating system returns a “0x00000124†exception.
Method 1: Disconnect all the external devices (printers, scanner, USB (universal serial bus) drives, etc...) Except mouse and the keyboard and then boot up.
If this corrects the issue then add the devices back one at a time until you discover the piece of hardware causing the issue. Then get any updated drivers\software for the device.
Method 2: You may refer the steps outlined in the link below
Resolving stop (blue screen) errors inWindows 7
[url=http://windows.microsoft.com/en-US/windows7/Resolving-stop-blue-screen-errors-in-Windows-7]http://windows.microsoft.com/en-US/windows7/Resolving-stop-blue-screen-errors-in-Windows-7[/url=http://windows.microsoft.com/en-US/windows7/Resolving-stop-blue-screen-errors-in-Windows-7]
Method 3: User favourite was able to sort this issue out by replacing the Network adapter, please refer the post dated Saturday, September 04, 2010 2:30 AM in the link below
[url=http://social.answers.microsoft.com/Forums/en-US/vistarepair/thread/6f961740-602e-42e4-bab4-7e2a8e0196df]http://social.answers.microsoft.com/Forums/en-US/vistarepair/thread/6f961740-602e-42e4-bab4-7e2a8e0196df[/url=http://social.answers.microsoft.com/Forums/en-US/vistarepair/thread/6f961740-602e-42e4-bab4-7e2a8e0196df]
https://linustechtips.com/topic/8210-i-need-help/#findComment-93292
