Hello.
I'm new to this forum and need help with something.
At the moment this is my specs:
Okay so basically my CPU is Bottle-necking my GPU and I'm looking a CPU that will give me the most out of my GPU. I will be using for Gaming & Rendering videos. So can you guys give me some suggestions? Also would a AMD FX-9590 Bottleneck my GTX 1080?
Thanks! :D
https://linustechtips.com/topic/820992-need-help/
Just now, TheDreadPirate said:
Hello.
Thanks! :D
about the fx-9590 im not sure because i never tried it or saw any benchmarks of it, but i would suggest getting a ryzen 1600x or even a ryzen 1700
https://linustechtips.com/topic/820992-need-help/#findComment-10289149
8 minutes ago, TheDreadPirate said:
Would an i7-7700K work well with the 1080?
Yeah but it won't be as good at rendering videos as a 1600 or 1700
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/820992-need-help/#findComment-10289231
What about gaming wise? What would be best?
7700k would be better for gaming by around 10%, though if you're monitor is 1080p 60 hz you won't notice the difference between any of the CPUs since they all can push way more than 1080p 60 hz.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/820992-need-help/#findComment-10289241
Cool. I will be playing in 1080p but I'm looking to get the best possible fps with these components.
Any more suggestions?
https://linustechtips.com/topic/820992-need-help/#findComment-10289246
If gaming is all you do then go for the 7700K + Z270 mobo if you want to OC or 7700 + B250/H270 mobo of you don't.
If I were you, the next upgrade after that would be my monitor to 4K or 1440p (ultrawide if you like) or a high refresh rate 1080p monitor.
https://linustechtips.com/topic/820992-need-help/#findComment-10289328
At 1080p your GPU will be idling around a lot no matter what you do, unless you set it to a higher resolution and then downscaling, which still won't amount to much other than the GPU usage going up :P I mean, it will be a substitute for AA in some sense.
At the same time, at 60Hz a high end CPU will also idle around, unless you let FPS uncapped at the risk of tearing. If you do, your system can push more than 60FPS, but your screen still will only show 60.
Bottom line: in your current setup, your GPU is overkill, but you can upgrade your CPU a bit. "Too much" CPU upgrade, and both your CPU and GPU will be overkill. Basically, you don't need such strong hardware for that screen. If you upgrade your monitor, then it's a different story. Until then, any CPU+GPU combination that gives you 60 FPS minimum in the games you play is equivalent.
https://linustechtips.com/topic/820992-need-help/#findComment-10289352
