It will, but not as much as some longer, heavier cards.
Desktop benching:
https://linustechtips.com/topic/820757-will-a-1080-sag/#findComment-10286642
7 hours ago, Steve Boberson said:
will it damage the motherboard? the motherboard i'm gonna use is Asus - PRIME B250M-PLUS Micro ATX LGA1151 Motherboard
Most likely it will not.
What can damage PCI-e lane, though, is if you start moving your PC around without properly securing your graphics card.
https://linustechtips.com/topic/820757-will-a-1080-sag/#findComment-10288191
