hello
i am thinking to buy new UPS and maybe https://www.cyberpower.com/ww/en/product/sku/UT1050E-FR could be enough
i want to plugin PC with 650W PSU and AOC G2460VQ6 monitor which using 25W, but i am not sure, i found that info on amazon, on official AOC website there isn't any info about Wattage
so what do you think? 630W would be enough to handle PC + 1 or 2 monitors, while i save everything and will shut down PC?
https://linustechtips.com/topic/820581-need-help-with-ups/
You should be alright for a short period of time however I believe you would be cutting it kind of close.  The numbers arent 100% accurate but plug your system specs into cooler masters program to gain a better picture of your power draw.
  • CPU
    i7 6700k overclocked to 4.7 GHZ @1.38v
  • Motherboard
    ASUS ROG Maximus VIII Hero Alpha
  • RAM
    32GB Gskill Ripjaws @3200mhz
  • GPU
    ASUS ROG Geforce 980
  • Case
    CoolerMaster HAF X
  • Storage
    500 GB SSD and 12TB mechanical HDD some soon to be split to NAS
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/820581-need-help-with-ups/#findComment-10284067
Just now, Maozi said:
ok ty
no worries and best of luck with your ups humt
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    CoolerMaster HAF X
  • Storage
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/820581-need-help-with-ups/#findComment-10284083
What matters more than your PSU size is what hardware you actually have in your system (or if you happen to know off the top of your head how many watts your system draws). You are probably not drawing anywhere near 650w if you have a normal gaming computer, certainly not under normal usage scenarios.
TLDR; 630w UPS is almost certainly big enough for your needs.
https://linustechtips.com/topic/820581-need-help-with-ups/#findComment-10284106
more or less my point as well
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    CoolerMaster HAF X
  • Storage
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/820581-need-help-with-ups/#findComment-10284114
1 minute ago, Maozi said:
master cooler calculator showed ~340W useage
so you have plenty of head room
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    CoolerMaster HAF X
  • Storage
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/820581-need-help-with-ups/#findComment-10284118
