How many lumens is enough?
Solved by vanished,
if you're talking a display, you don't have much choice. the vast majority are between 300 and 250, which is more than enough for all but an outdoor use case scenario, and they can also be turned down if it's too much.
Phenz ·
Posted in CPUs, Motherboards, and Memory2 -
SpookyGhosts ·
Posted in New Builds and Planning1 -
1
mrtwonavels ·
Posted in Cooling0 -
GuiltySpark_ ·
Posted in Tech News15
