Top vent filter mod
Solved by W-L,
43 minutes ago, Sgt. ShadoWolf said:Does anyone know of possibly a premade vent filter for the top fan since NZXT forgot to add that with the additions to the elite
Here you are as said if it's exhaust it really doesn't need a filter but that being said I personally use filters on every opening in my case just to prevent dust from settling into the system when it gets turned off.
