Low end GPU, need advice
Solved by quiffghtyu,
1 minute ago, MadOverclocker said:Yes that's why I asked for the HD 8570 because it's dirt cheap and has 50 tdp or for the gt 710 that has 30 watt tdp and has litle less performance. If I were to get a 750 Ti I would gave her my GPU because like, look at my specs!
I have a GT 710, it's useless. I wouldn't spend money on that if you're looking to play any game.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases3 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
