Hey,
(not sure if this is the right forum)
I have the problem that I have static on my front panel audio. (both mic and speaker/headphone)
If I unplug the front usb ports there is no static.
I looked at the board where everything is on and saw that the audio ground is connected to the usb ground (thats atleast what it looks like)
I marked the trace I mean on the picture
Here is the same picture without my "drawing"
So would it fix the issue by just destroying that connection?
EDIT: My case is an super cheap Aerocool Strike X One
My System:
CPU: Intel Core i7 920
Graphics Card: KFA2 GTX 1060 3GB OC
RAM: 4x 2GB Hynix 2x 2GB Corsair (12GB) DDR3
MB: Some acer one (It's crap)
HDD: 3TB Segate Desktop HDD (Data) 500GB WD Blue (Video) 1TB Hitachi (Anime)
SSD: 250GB WD Blue
https://linustechtips.com/topic/818768-static-on-front-audio/
To me it would be more logical that the big surface that connects to multiple pins is the ground. USB can introduce a lot of EMI/static to the groundplane, so either use the backports of your Audio or don't use USB.
https://linustechtips.com/topic/818768-static-on-front-audio/#findComment-10262890
I took some more pictures
20170807_191737.thumb.jpg.5010e658cdf18b175ad65cb982f19e18.jpg20170807_191942.thumb.jpg.8e40269efb58f01920b230e871cd4457.jpg20170807_192207.thumb.jpg.4d71a72f80298c9f0a59e2d4b52b3f8a.jpg
And here is the pinout I found:
My System:
SSD: 250GB WD Blue
https://linustechtips.com/topic/818768-static-on-front-audio/#findComment-10262982
Wouldn't it be possible to "disconnect" them?
My System:
SSD: 250GB WD Blue
https://linustechtips.com/topic/818768-static-on-front-audio/#findComment-10263053
You'd have to source the groundwire from someplace else. Maybe that can work. But it's cheaper and simpler just to get a jack or USB extension cable.
https://linustechtips.com/topic/818768-static-on-front-audio/#findComment-10263204
If I see this right the usb port (the one who is connected to Audio ground) is also connected to USB Ground.
I Looked at this: repairpc_0423.jpg
Yeah I thought about that
My System:
SSD: 250GB WD Blue
https://linustechtips.com/topic/818768-static-on-front-audio/#findComment-10263226
