Now, before y'all lynch me for doing a mining build, this will be out of 100% spare parts.
I'm thinking of doing a mining build while in college, as we don't get charged for electricity.  This way, I can let the PC run all day without worry to my personal bill.
It won't be nothing extravagant.  An old Core 2 Duo and either GTX 460 SE or HD 6770.
I figured, since I wouldn't have to pay for anything for it, I'll technically make 100% profit no matter how much or little I make.
I'm just wondering, is it worth it and such, and what all should I do with this build to get it ready?
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
https://linustechtips.com/topic/818429-mining-build/
Not sure if you can get anything out of old cards with only 1gb of vram.  You could try it and see.  You would probably be better off letting your desktop you have in your signature mine while you are not using it.
https://linustechtips.com/topic/818429-mining-build/#findComment-10259778
You're right, you need at least 4GB of VRAM to mine Eth and some other coins.
Not sure about all coins but some of the big name coins need a good chunk of VRAM.
Mining with nicehash would be your best bet, it will benchmark a bunch of coins and mine what's most profitable.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/818429-mining-build/#findComment-10259832
Thing is I leave my main rig at home.  I have a gaming laptop that I use at school.
Hmm... Nicehash?  Is this some program?
Like I said... since I ain't paying for parts or electricity, I make 100% profit anyways.
Bazzite Box (HTPC):
https://linustechtips.com/topic/818429-mining-build/#findComment-10259852
Nicehash is a mining setup that allows you to mine as part of a pool.  It will automatically select the most profitable coin to mine for your setup at that current time and automatically change it for you when another coin becomes more profitable.   It also converts everything over to bitcoin to pay you that way you don't have 5 different coins you get paid in.
https://linustechtips.com/topic/818429-mining-build/#findComment-10259937
And how would I convert bitcoin to say... US currency, is it tradeable through PayPal or something?
Bazzite Box (HTPC):
https://linustechtips.com/topic/818429-mining-build/#findComment-10259943
you have to get a bitcoin wallet or wallet for a specific coin you are mining.  from there you have to set up a transfer to your normal bank account.  once this is setup yes you can convert bitcoin to dollar via transfer to your bank account.  I use coinbase.com but check around there may be better options.
https://linustechtips.com/topic/818429-mining-build/#findComment-10259959
Alright, thanks.  Care if I PM you later if any issues arise (I won't be setting this up for at least another two weeks)
Bazzite Box (HTPC):
https://linustechtips.com/topic/818429-mining-build/#findComment-10259972
Just now, Beowulff83 said:
Sure, cant guarantee an immediate response because of my work schedule.
Makes sense, I understand.
Bazzite Box (HTPC):
https://linustechtips.com/topic/818429-mining-build/#findComment-10259996
