So I bought a G920 Driving Force wheel to use on my PC. For an hour or so the wheel was working fine until my pc started to slow down significantly and programs stopped responding. So, like I usually do when I have a PC issue like this I restarted it, and now my pc will not boot. I tried multiple things to get it to boot, but I have determined it's due to bad drivers which I get when I connect the G920. I formatted my HDD and reinstalled windows completely, and it booted fine and worked fine. Plugged in the wheel again, and the same thing happened. Slow performance, so I restarted and no boot again. My PC just sits at motherboard opening screen, and sometimes I can enter bios, sometimes I can't. My drive with said drivers installed isn't even a boot option. This is all happening because of the G920 drivers, and I'm not sure what to do. I confirmed its a driver issue because if I dont connect the wheel my PC works as usual. Any advice is appreciated, thanks :)
i7 4790
GTX 1070
16gb ddr3
Windows 10
https://linustechtips.com/topic/817879-steering-wheel-driver-issues/
11 hours ago, manikyath said:
i feel like the G920 is just very bad timing with something else in your system kicking the bucket...
It's only after I install the drivers for the wheel does it cause me issues. I can format drive and use a fresh install of windows and have no issues at all. I'm doing that currently, no issues with the system, gaming fine and restarts fine.. it's so odd
with the wheel plugged in, but no drivers installed?
