nope. not possible.
bandwidth is shared.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/817685-usb-30-extension-speed/#findComment-10252861
Just now, peeeej said:
Ohhhh alright. So basically, two ports being utilized at the same time will have a speed of 2.5Ghz each, something like that
2.5Gbps each yes.
but bandwith is also dynamically allocated, so if one port needs 4Gbps, and the others only need 0.5Gbps, then the one that needs more can get more, as long as the total is not more than 5Gbps.
(Also it's Gbps (Gigabits per second), not Ghz.)
Laptop:
https://linustechtips.com/topic/817685-usb-30-extension-speed/#findComment-10252869
Just now, RadiatingLight said:
2.5Gbps each yes.
Yeah sorry mistype :))) Thanks for your help man. Big help :))
https://linustechtips.com/topic/817685-usb-30-extension-speed/#findComment-10252877
