Ok So I Started Upgrading my Computer and taking out the parts(Cpu, Powersupply and Hard drive) from my old one and putting them in a new AMD 3+ Motherboard and Case) I also bought a Graphics card for later but 2-3 Hours in the Building phase Everything is set and plugged in I turn on thr power from the case the fans turns the Motherboard, Hard drive, Ram and CPU is Receiving power from the Power Supply and it appears to be all functional however when I plug in my VGA Monitor it keeps saying No Signal. I Tried this with 3 other moniters and even another VGA Cable and there's nothing I want to know what is wrong or if this is just Really Bad luck.
8/5/17 Edit
Here is the parts I am using https://pcpartpicker.com/list/Ht6dhq (*Case and Monitor not shown)
https://linustechtips.com/topic/817466-first-time-upgrade-need-help/
you need a gpu. is your monitor plugged into your gpu?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Specs?
Have you tried turning it off and on again?
3 minutes ago, Need-Help said:
So everything powers on, but you didn't mention your graphics card powering on.
I would power everything down, disconnect the PSU power cable, Re-seat the graphics card (and make sure it actually clicks), reconnect the PSU power cable, and try again.
When I was younger, I made a similar mistake. The graphics card wasn't seated properly.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
I'm Not sure if the graphics Card Fully Powered on but It's enough to turn the fan on and produce heat.
17 minutes ago, Need-Help said:
If you mean Swapping jumpers the Covering 2/3 pins to the other side, then yes I did do that and still Nothing
Did you put it back where it started and was your psu off?
Want to custom loop?  Ask me more if you are curious
For the First time No, and no display
Second I tried reshooting it again with the Pins back
third time I turned it off to move the pins but while it was still off I moved it back
and all of the times I moved the Pins I had my power supply off
