Hey guys I haven't been on in a while but,
I am working on doing a podcast and have been using one mic and am deciding to move to two, however I'm a bit confused on how to do that. I record useing my laptop but I am of the understanding that I need a sort of sound mixer for that but I'm confused as to exactly what.
I've found this below
http://www.zzounds.com/item--BEHMX400?siid=38044&-RgyiwglKLbKs7uR3h8nhlmyzUYtYGVfXXV8uRVSWwCXRuRoCkowQAvD_BwE=
Questions:
Is this the right idea?
If yes will it work or is it too cheap/bad quality
What would you reccomend if no to any above.
Thank you I'd appreciate it
https://linustechtips.com/topic/816651-microphone-combiner-thing/
use audacity and record / mix them both together?
why do you want to use two mics? one for you and one for another person, or one for your left ear and one for your right ear? xD
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
It's to power to the microphone a audio interface with two XLR inputs
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Just now, cleb said:
One per person. ?
anyways
use audacity, you can have it record both mics at once and you can mix them together too, or edit them in post.
