So i have overclocked my ryzen 7 1700 to 3,8ghz with 1,3volt. This seems to be the most stable. When i ran aida64 it ran all well and smoothly until about 45min into the stress-test, when it shut down and the error message "hardware failure detected" pops up. I am scared, should i be scared? What should i do? More voltage? Less frequency? Or is it stable?
https://linustechtips.com/topic/816370-noob-needs-oc-help/
lol does it SEEM stable if it just shuts down on you?
did you touch SOC voltage?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10238500
It does not shut down, it works fine. Its just Aida64 that says there is a hardware failure during the test.
The only four things i touched was:
CPU frequency
CPU core voltage
I also have A-XMP on.
(msi motherboard)
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10238518
AIDA64 can detect instability and shut the test down before it crashes the system (it's not doing it successfully always though). Your overclock isn't stable.
Either back down your overclock or apply more voltages. Can't suggest what you should do between those two as I'm not familiar with the AMD platform.
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10238532
AMD States that 1.35 volts is the ceiling for OC. sure you can go higher, but at your own peril. i've already blown through one 1700X exceeding this voltage, and i'm apt to state that they're guidance should be followed.
System specs:
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10238565
1.37 / 1.39 is a safe daily driver voltage the boosting voltage stock will go higher than this, I got in on day 1 and have my current oc at 3.95mhz @1.39 under full load ran aida64 for hours with no issues I am on water so this will come into play
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10238644
First thing make sure memory is stable before overclocking the CPU at all running memtest is a great way to do that.
Once you make sure your memory is stable like 1000% coverage go here for more information on how to do that
http://www.overclock.net/t/1628751/official-amd-ryzen-ddr4-24-7-memory-stability-thread
Most likely your memory is not stable and that is why its crashing. Also what was the temps in the system when it crashed?
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10239659
about 77 degrees celcius
https://linustechtips.com/topic/816370-noob-needs-oc-help/#findComment-10241134
