4 minutes ago, jcw150 said:
I'm looking for a decent watercooling pump for a loop with a CPU, GPU and 2 rads.
I want to spend as little as possible but do want a quality product so aren't getting a budget as such (I'm from the UK if that helps).
Thanks
I used the EK P360 kit, gets you decent parts that you would actually buy separately. It all comes in a big box, but inside that, everything is individually packaged as if you bought it separately.
It would be a piece of cake to add a gpu block and extra rad.
The d5 pump res combo unit is really powerful, when bleeding the system, the pump gave the tap I was using to keep the reservoir full a good run for its money, pumping through a block and rad. (I have fairly strong water pressure at my house).
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
Thanks
D5 pump would be a good option, as said the P360 kit is a good option with a nice quality pump.
17 minutes ago, unknownmiscreant said:
SNIP
3 minutes ago, W-L said:
SNIP
I already have most other stuff but my pump is crap so the the kit is not needed.
So I'm not sure whether I should go with a DDC or D5 pump, do you know what the advantages of each are?
D5 has higher flow rate.
DDC has higher pressure.
DDC generates more heat.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
I would suggest the D5, as said the DDC does have more pressure and lower flow but also is more noisy and isn't actively cooled by the fluid so it's recommended to run it with  heatsink in most cases.
That sounds about right.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
http://www.watercoolinguk.co.uk/p/Alphacool-VPP655-G14-inner-thread-including-Eisdecke-D5-Acetal-V3_56226.html
Would you say that is a decent offering and can it be mounted on its side?
Yeah that's a good option as it is the version which you can set different speeds manually. In most cases you don't need to run the pump more than 50%, I personally leave mine in idle for the loop to keep it silent.
Ok thanks for your help :)
Thanks @unknownmiscreant as well
