So, i decided to finally build a game server for me and my friends. I started looking into old server cpus, eventually i found a great deal for a e3-1230 for around 60 bucks (not v2,v3 or anything like that, just e3-1230)
and then i went and searched for motherboards that is compatible with that cpu, but i am still not sure which will work or not.
I've found one that might work: Asrock Z68 Pro-3 M Intel Z68 mATX
also heard that z87 works too.
i am still not sure. can you guys give me some advice on what works or not?
https://linustechtips.com/topic/816003-will-it-work/
Thank you for such a quick reply, but i have a question, The motherboard listed above (Asrock Z68 Pro-3 M Intel Z68 mATX) does not have e3-1230 listed in the supported cpu list, it only listed e3-1230 v2, so i want to confirm that it wokrs, it would work, right?
https://linustechtips.com/topic/816003-will-it-work/#findComment-10234522
SHOULD work. The bios might need to be flashed.
Im hosting game servers on a q8300. Might be cheaper to find an old OEM machine and throw one of those in it.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/816003-will-it-work/#findComment-10234561
10 minutes ago, Forever_Onion said:
Q8300? not really for me, planning to host heavily modded game servers that struggles to run on i3. So yea, Q8300 not for me. also is 32GBs of ddr3 1333 reg ecc micron ram worth 100bucks? They are second hand and should work right?
Server Ram 4GBx8=32GB(DDR3-1333 REG ECC  MEMORY Module
You dont have a motherboard that supports that type of ram ¨ecc or Error-correcting code memory¨ wil only work on Xeon E5 family and AM4 motherboards. If you want a motherbord fot that type of ram look for Cxx chip set or X99  Its ddr3 not 4 :S
Your motherboard ram requirements.
  • Memory
    1. 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
      * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
    2. Dual channel memory architecture
    3. Support for DDR3 2133/1866/1600/1333/1066 MHz memory modules
    4. Support for non-ECC memory modules
    5. Support for Extreme Memory Profile (XMP) memory modules
    (Please refer "Memory Support List" for more information.)
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
https://linustechtips.com/topic/816003-will-it-work/#findComment-10234623
1 minute ago, Forever_Onion said:
Right, forgot that. Thank you.
Then any ddr3 without ecc would work?
Yes look at my first post for more info ^
https://linustechtips.com/topic/816003-will-it-work/#findComment-10234658
 If you want help for a new server build plz start a new topic in this tread https://linustechtips.com/main/forum/84-servers-and-nas/
Thare make a smal list
Intro/wat you want to do white it:
I have :
I need:
Nice to have:
Buget / Ware you form :
https://linustechtips.com/topic/816003-will-it-work/#findComment-10234674
