Help with a non-posting build
Solved by PorkishPig,
3 minutes ago, linkofcourage said:https://pcpartpicker.com/list/sHcRPs
Hello, above is my new build, minus the GPU which is yet to come in, and i was putting it together to get windows on it, but it won't post, anyone maybe know the problem? I think it might be the RAM, but i dont have any other DDR4 sticks to test with, and they're too expensive for me to just up and buy a set to test with so idk.
Ryzen CPUs do not have integrated graphics like Intel processors do. If you are plugging your monitor into your motherboard, you will not see it post. You'll have to wait for your graphics card to come in to use your new build.
